Stick the cutting templates on the inner tube and cut out the inner tube
Double sided is probably the most comfortable, but you can use any tape to stick the template to the inner tube. Probably it's a good idea to cut the inner tube in half lengthwise and wash it beforehand. Then cut out the inner tube.
The total length of the bow tie should be 52.5cm + your neck circumference.
3
Tie the bow tie
Find some tutorial how to tie a bow tie and tie the bow tie. The inner tube is elastic, so it can be pulled over your head without untying the bow tie.
