Ensuring that I've got >22mm of eye relief, I've angled the combiner inwards by 5 degrees so that the 55mm fresnel lens is optically centered (as apposed to a 50mm lens with very tight tolerances or an uncentred 55mm lens).
The 60mm combiners give ample space for the FOV desired, but a 55mm one might just about work too:
