v1.08 Firmware released
01/06/2023 at 00:49 • 0 commentsA new animation mode has been added (#5, Johnny Five) to allow individual digit color control, use left/right (Needs Input!) to "select" the active digit, which will blink twice in white and then the up/down motion of the joystick will change the color for that digit column. The colon color can also be changed.
The currently selected animation mode will now also be briefly displayed with each click of the joystick.
To mark the occasion, here is the new firmware running inside a lovely purpleheart case. More firmware improvements are coming :)
Open Source Hardware Certified!
10/01/2022 at 00:45 • 0 commentsThanks to the help of the fine folks over at OSHWA, the Foxie Clock 2.0 is now Certified Open Source Hardware, ID: US002126. #excite #oshw
An "Edge-Lit Masterpiece"
09/28/2022 at 03:26 • 0 commentsI was extremely honored today that Tindie wrote a blog post about my clock project. Thank you!!
https://blog.tindie.com/2022/09/foxie-clock-2-0-is-an-edge-lit-masterpiece/
