Note on Cricut CRV001 Hardware
A project log for Cricut Hacking
Putting Marlin 2.x on the Cricut Expression because, well, why not? Also, some reverse engineering on CRV001
jc-nelsonJ.C. Nelson 09/29/2022 at 19:181 Comment
In case someone else is playing with this. The CRV001 has an ATMega128 MCU (fewer timers), a 1x16ish LCD. The steppers work the exact same, the pen test sketch doesn't work at all (it's doing something, but I can't tell what) and the LCD sure seems to be a 4 bit parallel style. Hopefully more on that later.
Ben Smith wrote 02/17/2026 at 10:36 point
how did you flash this unit, I have assume flashing a atmega 1281 firmware will not work due to the pin and timer changes.
