Updating Designs
A project log for Modular OTS Cyberdeck Creation Kit
A suite of printables designed around using (mostly) off-the-shell parts to make your own custom computing platform/ Cyber Deck/ Lapdock
sp4mSp4m 3 days ago0 Comments
Howdy! It's been about 3 years since I started this project, and I've learned a few things since then.
1. I should have standardized the size of modules to be multiples of 10.
2. I should have spaced the holes at multiples of 20 or 10
3. Cable coming out of the top is functionally inferior to cable sticking out the back
4. I should have designed it for "normal sized" print beds.
5. More port clearance everywhere. I did all this work to integrate a docking station, it kills me when I can't get to a port I need.
6. Track pad's charging port is not accessible without removing the keyboard. This is a big one.
7. There is interest in a right-handed variant. I think a literal X-axis swap is possible.
So I'm gonna do those things!
