A couple of nights, and I have a very nice 2.0!
Above is the all-new "Mighty-Righty" variant, where the trackpad is positioned to the right of the keyboard.
Model is now split, for printing on "normal" print beds
20mm standardized separation between mounting holes
"chamfer" technology applied to screw holes make heat-set inserts no longer mandatory,
Removal of mounting holes for that one weird bracket I found, replacement with standardized holes.
Optimizations to improve FDM printing and reduce support needs
Design optimization, including 90 degree angle for rear of chassis, addition of optional screw holes for mounting rubber feet.
Design improvement, to make embedded device controls and plugs accessible.
Sp4m
