The project is simply using the V-USB library to allow the ATTiny85 controller to act as a USB keyboard.
- The project features:
- 2-bit Dip switch:
Allows the user to select between 4 randomly generated multicase alphanumeric passwords.- Push button:
- Sends the selected password to the computer.
- If the user pressed the button for 10 seconds, new set of passwords will be generated and the "ScrollLock" LED will flash indicating a successful generation.
That's it.
- Future enhancements:
- Switch to SMD components.
- Use bigger controller to support more passwords.
- Add some sort of protection in case the USB stick was stolen.
- 3D printed key-chain enclosure .
All your comments and remarks are appreciated.
mwahid
Amos
Max.K
Dave
I'd suggest switching over to the attiny84A it's lower power and is basically the same chip but with more I/Os. If you're switching to SMT then you might as well.
I don't think the 85 has enough, but you might be able to juggle the I/Os with more dipswitches. IE: Have one switch determine input/output mode, then another set of switches flip on the physical IOs to a serial interface pinout and password selection IOs. You could also have something like a 4 or 8 pin dip switch with a shift register to interface a longer password list.
