I've got the print and 90mm is a nice size alright, but as it turns out, I rotated the Tetrinsics in the opposite direction to what I needed because of Team Aesthetic. Oh and Finger2 still collides with the motor, so that has to be forcefully moved. The original cutout design wasn't going to work, and since Finger3 has the most travel (thus tolerance for movement), I moved it so that the Tetrinsics were colinear.
The sad thing is... imagine if the stars aligned and out of pure coincidence did everything line up:
