Start-EditorServices.cs:
HostName:
- Only significant use: hostInfo.name = HostName
hostInfo:
CreateConfigObject():
EditorServicesLoader psesLoader:
EditorServicesLoader.Create():
psesLoader.LoadAndRunEditorServicesAsync(): - NOTE: psesLoader should call on an EditorServicesRunner object
- declaration
- calls in order:
- LogHostInformation
- declaration
- just dumps host info to logger
- CheckNetFxVersion
- declaration
- Checks .NETFramework version against .NET 4.6.2. Doesn't throw error, but dumps a warning to console
- UpdatePSModulePath
- declaration
- adds BundledModulePath to $env:PSModulePath
- ValidateConfiguration
- declaration
- ensures that Debug and Language Service Transport are not both set to STDIO
- Ensures there is "PSHost" object (this is the MonadShell/PowerShell (MSH) Runspace)
- LoadEditorService
- declaration
- Wrapper for EditorServicesLoading.LoadEditorServicesForHost()
- Which is a "no-op" that just ensures that Microsoft.PowerShell.EditorServices.Hosting assembly is loaded
- This triggers an AssemblyResolve event
- _editorServicesRunner = new EditorServicesRunner(_logger, _hostConfig, _sessionFileWriter, _loggersToUnsubscribe);
- declaration
- EditorServicesRunner.RunUntilShutdown()
- Wraps CreateEditorServicesAndRunUntilShutdown()
- declaration
- Wraps a Try...Final() block
- calls CreateHostStartupInfo();
- if debug, sets debug server to RunTempDebugSessionAsync(hostStartupInfo).ConfigureAwait(false);
- unsubscribes from host logger (I assume from bloating it? I don't remember this bloating the host logger??)
- calls WriteStartupBanner();
- which is no-oped due to not having an entry in for the startup banner argument PowerShellEditorServices.Hosting/Commands/StartEditorServicesCommand.cs
- sets languages server to PsesLanguageServer languageServer = await CreateLanguageServerAsync(hostStartupInfo).ConfigureAwait(false);
- declaration (PsesLanguageServer)
- hostdetails gets processed in StartAsync() as an argument to AddPsesLanguageServices()
- declaration for AddPsesLanguageServices()
- this is done in a callback passed to options.WithServices
- options is a parameter for a callback passed to LanguageServer.From()
- this call has the this signature
- the definition assoc'd with that sig is a wrapper for From(Action<LanguageServerOptions> optionsAction,outerServiceProvider,CancellationToken) where optionsAction is the callback
- the def
- this function is also a wrapper for From(LanguageServerOptions options, ...)
- The LanguageServerOptions type is an implementation of LanguageProtocolRpcOptionsBase<LanguageServerOptions>
- which is an implementation of JsonRpcServerOptionsBase<T>
- which has a method called WithServices(Action<IServiceCollection> servicesAction)
- declaration
- servicesAction is a callback with the signature: servicesAction(
- calls languageServer.StartAsync();
- starts debug server
- calls languageServer.WaitForShutdown()
- then final() resubs the host logger
- Writes Starting State to Session File
- return Task.Run(_editorServicesRunner.RunUntilShutdown);
- and a whole bunch of calls to _logger
psesinternalhost also gets wrapped by EditorOperationsService
an alias for psesinternalhost is IInternalPowerShellExecutionService executionService
RunspaceFactory is an SMA class! Which means we finally found what it hostname is used for lol
gets passed:
Runspace runspace = RunspaceFactory.CreateRunspace(PublicHost, initialSessionState);
EditorServicesConsolePSHost also uses hostname as EditorServicesConsolePSHost.name (which is grabbed from PsesInternalHost.name)
gets passed to CreateInitialPowerShell, but it doesn't use hostinfo.name
also gets refactored into PsesInternalHost
as PsesInternalHost.hostinfo and PsesInternalHost.name (hostinfo.name)
HostStartupInfo:
Gets passed to omnisharp as part of PsesLanguageServer creation
AddPsesLanguageServices() can be used to do this
EditorServicesConfig:
Passed to:
<EditorServicesLoader>psesLoader.<EditorServicesRunner>_editorServicesRunner.<EditorServicesConfig>config.<HostInfo>HostInfo.name
<EditorServicesLoader>psesLoader.<EditorServicesConfig>_hostConfig.<HostInfo>HostInfo.name
Dumped by:
EditorServicesLoader.LogHostInformation()
Injected by:
EditorServicesLoader.LoadAndRunEditorServicesAsync() to EditorServicesRunner
