ExtendExtensor.stl
A new stl files has been updated with the name of ExtendExtensor.stl that consist of a turbine extension unit that can be linked with other extension units, so the turbine diameter can be extended more in case there is few wind available and you are using the 2 generators in the device.
Standard Tesselated Geometry -
45.59 kB -
10/15/2022 at 19:20
