Bluetooth speaker that’s shaped and functions as the helmets used by Daft Punk.
Board Legend.jpgLabels and descriptions for buttons and header pins on boardJPEG Image - 152.53 kB - 08/07/2023 at 02:41 |
DevBoard_v0_schematic.pdfEagle schematic for Development Board v0Adobe Portable Document Format - 303.44 kB - 12/06/2022 at 19:58 |
Now that most of the software work is in good shape, I'm ready to begin prototyping how the size of physical speaker to look, and how the mounting will work. I printed out DmitriK42's Thomas helmet design at 40% scale to get a feel for the size. This gives me a good starting point, and hopefully it will make planning out the form factor PCBs for the control and LED boards an easier process.
Lots of progress since the last update, the most major being switching from Arduino to ESP-IDF for the dev environment:
Used EPS32 A2DP library to setup dev board as a Bluetooth audio sink and generate I2S data to send to audio amp. This library also allows for receiving raw incoming audio data via a callback function, I then performed an FFT on the incoming data and used the results to update the display.
Work left to do:
Designed development board to vet out project design while allowing for easy access to key test points (Power rails, I2C, I2S, and UART) and to test different hardware gain settings for the audio amp. This development board includes:
The development board was fabbed and assembled by JLCPCB, shown below:
