Used EPS32 A2DP library to setup dev board as a Bluetooth audio sink and generate I2S data to send to audio amp. This library also allows for receiving raw incoming audio data via a callback function, I then performed an FFT on the incoming data and used the results to update the display.
Work left to do:
- Volume and pairing control via buttons
- Status LED to reflect pairing and battery status
- Audio playback from SD card
- Text and animations when not playing audio
