NixC is a project where I wanted to show the way to connect two opposite designs. Old-fashioned tube displays coupled with classic hand woodwork and modern technology are what represent NixC.
This was my second attempt to create a clock and further develop my hardware ad software design skills. I have made two versions with vertical and horizontal tubes. NixC could be controlled via Bluetooth to set the backlight color and brightness and adjust the time and sleep mode to save the tubes. It has a light sensor to detect ambient conditions and set automation for sleep mode. It is also possible to display color animations under the tubes.
