What a busy few weeks it has been! Double shifts on the job warranted an extended vacation. 2,000 kms added to the odometer, and we're back!
My biggest hurdle currently is trying to increase the PWM rate. Even 1/255 is quite bright on Arduino. As much as I want to avoid adding a 5940, it may produce a more effective light output.
Thanks to those of you who have skull'd the project. It really helps fight against the procrastination.
XBrav
