Part-DB - Open Source inventory software
Part-DB is an Open-Source inventory management system for your electronic components. It is installed on a web server and so can be accessed
Public Chat
Part-DB is an Open-Source (AGPL 3.0) inventory managment system with a focus on electronic components (but can be used for other things too). It is installed on a web server and so can be accessed with any browser without the need to install additional software. GitHub Repo: https://github.com/Part-DB/Part-DB-server
If you want to try out Part-DB you can find a demo instance under https://part-db.herokuapp.com
See the GitHub Repo for more info.
Features include:
  • Inventory management of your electronic parts. Each part can be assigned to a category, footprint, manufacturer and multiple store locations and price information. Parts can be grouped using tags. You can associate various files like datasheets or pictures with the parts.
  • Multi-Language support (currently German, English, Russian, Japanese and French (experimental))
  • Barcodes/Labels generator for parts and storage locations, scan barcodes via webcam using the builtin barcode scanner
  • User system with groups and detailed (fine granular) permissions. Two-factor authentication is supported (Google Authenticator and Webauthn/U2F keys) and can be enforced for groups. Password reset via email can be setuped.
  • Optional support for single sign-on (SSO) via SAML (using an intermediate service like Keycloak you can connect Part-DB to an existing LDAP or Active Directory server)
  • Import/Export system (partial working)
  • Project management: Create projects and assign parts to the bill of material (BOM), to show how often you could build this project and directly withdraw all components needed from DB
  • Event log: Track what changes happens to your inventory, track which user does what. Revert your parts to older versions.
  • Responsive design: You can use Part-DB on your PC, your tablet and your smartphone using the same interface.
  • MySQL and SQLite supported as database backends
  • Support for rich text descriptions and comments in parts
  • Support for multiple currencies and automatic update of exchange rates supported
  • Powerful search and filter function, including parametric search (search for parts according to some specifications)
  • Automatic thumbnail generation for pictures
  • Integration with KiCad: Use Part-DB as central datasource for your
    KiCad and see available parts from Part-DB directly inside KiCad.
With these features Part-DB is useful to hobbyists, who want to keep track of their private electronic parts inventory, or makerspaces, where many users have should have (controlled) access to the shared inventory.
Part-DB is also used by small companies and universities for managing their inventory.
Documentation and installation guides can be found here: https://docs.part-db.de/
  • Part-DB 2.8.0: Scanner improvements, KiCad improvements and more
    Jan B. • 03/01/2026 at 23:19 • 0 comments
    Part-DB 2.8.0 has some big new features:
    The barcode scanner was improved. In info mode the page will directly show a preview of an found part.
    The biggest thing however is the ability to create a new part based on an distributor barcode: If you have ordered parts with digikey, mouser, LCSC or Amazon, you can just scan the barcode and Part-DB will parse the barcode, fetch the informations of the parts and redirect you to the part creation page with all infos prefilled.
    Handling with external barcode scanners was also improved: The scan field properly parse and displays non-printable characters now. And by configuring a special präfix on your barcode scanner, you can directly scan a barcode and open the part page, no matter where in Part-DB you currently are. No need to open the scanner app first.
    KiCad integration improvements
    The KiCAD API of Part-DB now returns caching headers to improve cachability in KiCad.
    Also Part parameters and part orderdetails will now be shown in Kicad if you want so.
    And more
    View the full list of changes in the release notes: https://github.com/Part-DB/Part-DB-server/releases/tag/v2.8.0
  • Part-DB 2.6.0: Updates from Web interface, Generic Webshop Provider, Part creation from URL and more
    Jan B. • 02/07/2026 at 19:21 • 0 comments
    Part-DB 2.6.0
    Part-DB 2.6. has some new big features:
    Update manager
    Thanks to @Sebbeben there is a new (experimental) update manager, allowing to update Part-DB directly from the Web interface, when it was installed via git.
    update-manager-interface
    It is for now experimental, users require the permission for it, and you need to explicitly set `DISABLE_WEB_UPDATES=0` in your `.env.local` to enable it. This might change in the future, if there is more experience with the reliability of the web updater.
    You can also update from the console line with the new `partdb:update` console command.
    Generic webshop provider
    There is a new generic URL provider, that allows to import rudimentary part infos from many different webshops. It works by parsing either the JSONLD or microdata provided by the webpage, which is used by search engine to show rich product results. The amount of data you can get from it, depends on the website, but it is normally the name, some description, an image, a category, the price and the shop's order number for the product.
    That way it is possible to easily import things from sellers, which have no specialized info provider. Just select the "Generic URL" as provider and use the URL as keyword. Alternatively you can also use the new "Create part from URL feature"
    Bases on the Generic URL provider there is now a specialized page to create a part from an URL. Just input the URL and it will try to to retrieve infos from it and offer to create a new part from it.
    If you input an URL from an existing info provider (like an TME shop URL), then it tries to delegate it to that provider, to get the more detailed results from it. Please note that this not works for all info providers yet.
    And more
    There is also an Info provider for conrad and some other smaller changes. See the release notes for detailed info: https://github.com/Part-DB/Part-DB-server/releases/tag/v2.6.0
  • Part-DB 1.17.0 out
    Jan B. • 03/31/2025 at 11:28 • 0 comments
    A new version of Part-DB 1.17.0 was released.
    See the full changelog here:
    https://github.com/Part-DB/Part-DB-server/releases/tag/v1.17.0
  • Part-DB 1.13.0 - PostgreSQL support, natural sorting and more
    Jan B. • 06/24/2024 at 11:49 • 0 comments
    # Part-DB 1.13.0 - PostgreSQL support, natural sorting and more
    ## PostgreSQL
    Part-DB now supports [PostgreSQL](https://www.postgresql.org/) as database. See [documentation](https://docs.part-db.de/installation/choosing_database.html) on how it compares with other database types.
    ## Natural Sorting
    Part-DB now supports natural sorting in part tables and tress.
    So instead of sorting elements like `DIP-14`, `DIP-28`, `DIP-4` , `DIP-8`, the elements now get sorted like expected as `DIP-4`, `DIP-8`, `DIP-14` and `DIP-28`.
    If you are using PostgreSQL or MariaDB 10.7+ then this kind of sorting is supported natively and natural sorting gets automatically enabled.
    If you are running SQLite or MySQL then it is possible to emulate natural sorting by setting the `DATABASE_EMULATE_NATURAL_SORT` to 1.
    Please note that this emulation can be very slow and might have some issues and quirks.
    # Full changelog
    See Release page: https://github.com/Part-DB/Part-DB-server/releases/tag/v1.13.0
  • Part-DB 1.11.0 - LCSC info provider, improved search and API
    Jan B. • 03/06/2024 at 11:50 • 0 comments
    LCSC info provider
    Part-DB now can use import part information from LCSC distributor. See documentation on how to use it.
    Improved search bar
    The search bar now makes suggestions for parts while typing. This should make searching much quicker in many cases.
    API improvements
    It is now possible to properly create new attachments and parameters on elements using the API like you would expect.
    Also, it is now possible to upload files to attachments via API and let Part-DB download URLs. See API docs for more info.
    Full changelog
    https://github.com/Part-DB/Part-DB-server/releases/tag/v1.11.1
  • Part-DB now featured on official KiCad website
    Jan B. • 02/19/2024 at 14:08 • 0 comments
    Part-DB is now featured on the official KiCad website under the external tools page:
    https://www.kicad.org/external-tools/
    Part-DB can be used with KiCad 8 as HTTP library as central inventory database.
  • Part-DB 1.10 - KiCad integration
    Jan B. • 12/07/2023 at 15:32 • 0 comments
    KiCad integration
    Part-DB now supports the experimental HTTP library feature in the KiCad nightly builds (KiCad 7.99). It allows to define metadata like the KiCad footprints and symbols on Part-DB parts and use Part-DB as libray inside KiCad.
    See here for more information.
    See Github release page for full changelog:
    https://github.com/Part-DB/Part-DB-server/releases/tag/v1.10.0
  • Part-DB 1.9.0 - Update existing parts from info providers, merge parts, part associations and more
    Jan B. • 11/25/2023 at 19:38 • 0 comments
    See Github release for full changelog:  https://github.com/Part-DB/Part-DB-server/releases/tag/v1.9.0
    ## Update existing parts
    Using the blue button in the tools tab on a part info page, you can update part info from an info provider. This means you can pull datasheets, price infos and more from digikey, octopart and more for existing parts.
    You still needs to review and manually choose what infos you wanna keep
    ## Merge parts
    You can now merge two parts together: If you have created two versions of the same part by accident, then you can now merge the two versions of the part into a single one. All information like datasheets, partLots, etc. are combined.
    ## Blue dot on newly created collection items
    Newly created items of a collection, which were not persisted to database yet, are marked with a blue dot on the delete item:
    This is especially useful when merging parts together or update parts from info providers.
    ## Part Associations
    You can now associate part with each other. This can for example be used to denote alternative/compatible parts, or what part replaces an obsolete part.
  • Part-DB 1.8.0 - REST API, Mouser info provider and more
    Jan B. • 10/15/2023 at 15:00 • 0 comments
    With the new Version 1.8.0 release, Part-DB offers a REST API to let external applications interact with Part-DB.
    It allows reading and edit datastructures, parts and projects via an JSON based interface, so you can write your own software that interacts with Part-DB.
    To access the API an application requires an API token, which is generated on the users settings page. API access is experimental and must be enabled on a per user/group basis with the correct permission.
    See documentation for an introduction on how to use the API. In your Part-DB instance under the /api/ path you will find an interactive documentation, that shows you all available endpoints and allow you to try them out.
    You can look up all available endpoints and available parameters in the demo: https://part-db.herokuapp.com/api
    (you will need to login with username user and password user first)
    See the GitHub Release page for more info: https://github.com/Part-DB/Part-DB-server/releases/tag/v1.8.0
  • Version 1.6.0 - API Integration of Octopart, Digikey and more
    Jan B. • 07/31/2023 at 22:39 • 0 comments
    Part-DB now offers an information provider system, which allows you to query various cloud sources for part information.
    For now only creation of new parts is possible based on cloud providers, in later versions it will be possible to also merge the information in existing parts.
    The system is built to be universal, with just a little provider specific "driver" and the remain is done by Part-DB. That way it is pretty easy to integrate new data providers (so most likely other vendors and databases which offers APIs) into Part-DB.
    For now the following data sources (which use the distributor APIs) are available:
    • Octopart
    • Digikey
    • TME
    • Farnell / Element 14
    Depending on the provider, your created parts will automatically have a name, description, manufacturer and footprint info, part parameters, datasheets, pictures and shopping information/prices.
    See documentation for more info, especially on the configuration.
    You can test the new features in the demo (you need to login as user first).
View all 16 project logs
kriyasri wrote 08/07/2023 at 11:06 • point
hi
Vedran wrote 08/06/2023 at 13:04 • point
This is an awesome tool! For years, I've used local folders to try and save datasheets and lessons learned with different components, but wasn't too happy with that approach. I've set this up last night, started migrating data and so far, it's been great! Well done!
klemen.zurga wrote 03/10/2023 at 08:42 • point
I tried it and I think they are on the right path! Its simple to set up and it works okay.
Jarrett wrote 01/04/2017 at 20:08 • point
I want you to know that I'm still following this!
Plan on setting up an instance fairly soon and giving it a shot. I don't like any of the other options I've found for component management
