The 5.55" AMOLED of E555HBM2 720x1280 has been tested.
A project log for SBC-T113 RGB/MIPI/LVDS/AMOLED/QSPI/MCU LCD
Allwinner T113-S4 SOC chip is a 2xCortex-A7+1xRISC-V+256M DDR3 processor with RGB_MIPI_LVDS_8080 LCD driver.
eleclabElecLab 12/28/2025 at 04:160 Comments
The 5.55" AMOLED of E555HBM2 720x1280 has been tested. Now the contrast ratio is set at 50%, and the power consumption of all white is still very large. The conversion board uses 3.3V. If the contrast ratio is 100%, it will lower 3.3V. The power consumption of the screen is recorded.
