The PSV1000 screen AMS495QA01 960x544 is OK
A project log for SBC-T113 RGB/MIPI/LVDS/AMOLED/QSPI/MCU LCD
Allwinner T113-S4 SOC chip is a 2xCortex-A7+1xRISC-V+256M DDR3 processor with RGB_MIPI_LVDS_8080 LCD driver.
eleclabElecLab 12/28/2025 at 09:190 Comments
Another oled is also OK. The PSV1000 screen AMS495QA01 960x544 is set with the highest contrast ratio. The power consumption of this screen is relatively low. It only needs two voltages of ELVDD ELVSS, which is the same as the E555HBM2 voltage value, and is driven by the same SGM8351A power chip.
AMS495QA01 video playback current is still low on a non-white background.
