A quick note on version numbers
11/28/2022 at 20:24 • 0 commentsWhat I'm calling "v1" here is tagged in the Git repo as "v0.1." What I'm calling v2 here is referred to in some commits as "v1.1", and is also (as of now) master. Hopefully that's as clear as mud. :)
...and with the frame, it's now done.
11/28/2022 at 20:20 • 0 commentsA printable frame is now included in the frame subdirectory of the Git repo (OpenSCAD source and STL included). It's assembled mostly with M3x12 screws and nuts (had to step up to M3x16 for the vertical connections between frames) and can be extended as far as you need to go. It accommodates both v1 and v2 boards (probably a capability only I will need, unless someone else built v1 that I don't know about).
