• Assemble the shell
    MakerM0 • 02/17/2023 at 07:23 • 0 comments
    I took the time to print the shell using a 3D printer, then sanded and painted it.
    It looks pretty good.
    If you use CNC, the effect will be better
  • add stopwatch function
    MakerM0 • 02/09/2023 at 08:39 • 0 comments
     The display of the stopwatch is controlled according to different keys;
    event is responsible for the display content;
    loop is responsible for controlling the operation according to the condition of keys.
    #include "stopwatch.h"
    static uint32_t record[8];
    static uint8_t id;
    static bool flag_start;
    static bool flag_pause;
    static bool flag_reset;
    static bool flag_update;
    static bool flag_record;
    static uint32_t time_pause;
    static uint32_t time_pause_sum;
    static uint32_t time_start;
    static uint32_t time_stop;
    static void init(void *data)
    	tmos_memset(record, 0, 8 * 4);
    	flag_start = false;
    	flag_update = false;
    	flag_record = false;
    	flag_reset = false;
    	flag_pause = false;
    	time_pause_sum = 0;
    	time_pause = 0;
    	id = 0;
    static void dispMs(uint32_t ms)
    	char buffer[15];
    	uint16_t x, y;
    //    UG_FillFrame(0, 0, 128, 25, C_BLACK);
    	UG_FontSelect(FONT_12X20);
    	UG_SetBackcolor(C_BLACK);
    	UG_SetForecolor(C_SNOW);
    	snprintf(buffer, 15, "%02d:%02d:%03d", ms / 1000 / 60, ms / 1000 % 60,
    			ms % 1000);
    	uint16_t title_width = UG_GetStringWidth(buffer);
    	UG_PutString((LCD_W - title_width) / 2, 1, buffer);
    static void dispRecord(uint8_t index)
    	char buffer[15];
    	UG_FontSelect(FONT_8X12);
    	UG_SetForecolor(C_DARK_GREEN);
    	snprintf(buffer, 15, "%02d:%02d:%03d", record[index] / 1000 / 60,
    			record[index] / 1000 % 60, record[index] % 1000);
    	UG_PutString(45, 28 + index * 12, buffer);
    static void enter(void *data)
    	// insert code
    	UG_FillScreen(C_BLACK);
    	dispMs(0);
    	UG_DrawLine(0, 25, 128, 25, C_GREEN);
    	for (uint8_t i = 0; i < 8; i++)
    		UG_PutChar(i + '1', 10, 28 + i * 12, C_DARK_GREEN, C_BLACK);
    		UG_PutString(45, 28 + i * 12, "__:__:___");
    	manager_startEvent(222);
    	manager_setBusy(false);
    static void event(void *data)
    	if (flag_update == true)
    		// 开始刷屏
    		uint32_t time_consume;
    		time_consume = millis() - time_start - time_pause_sum;
    		dispMs(time_consume);
    	if (flag_record == true)
    		record[id] = time_stop - time_start;
    		dispRecord(id);
    		id++;
    		if (id >= 8)
    			id = 0;
    	if (flag_reset)
    		flag_reset = false;
    		flag_start = false;
    		flag_pause = false;
    		time_pause_sum = 0;
    		time_pause = 0;
    		id = 0;
    		dispMs(0);
    static void loop(void *data)
    	KEY_TYPE key;
    	key = HAL_KeyGet();
    	switch (key)
    	case KEY1_LONG:
    		manager_switchToParent();
    		break;
    	case KEY1_DOWN:
    		if (flag_start == false)
    			//first
    			time_start = millis();
    			flag_start = true;
    			flag_update = true;
    		else
    			if (flag_pause == false)
    				flag_record = true;
    				time_stop = millis() - time_pause_sum;
    			else
    				time_pause_sum = millis() - time_pause + time_pause_sum;
    				flag_pause = false;
    				flag_update = true;
    		break;
             //pause
    	case KEY2_DOWN:
    		flag_pause = true;
    		time_pause = millis();
    		break;
    		//reset
    	case KEY3_DOWN:
    		flag_reset = true;
    		break;
    	default:
    		break;
    static void quit(void *data)
    	// insert code
    	manager_stopEvent();
    	manager_setBusy(true);
  • Add shutter function
    MakerM0 • 02/09/2023 at 06:43 • 0 comments
    Split GIF image in frames (ezgif.com)
    I use this website to convert gif files to multiple jpg files and then to .c files, use TMOS to update a picture every 100ms, and perform animations when the keys are pressed.
    #include "shutter.h"
    #include "img_shutter.h"
    #include "img_shutter_96.h"
    #include "hidconsumer.h"
    #define IMG_NUM (img_shutter_96_height/img_shutter_96_width)
    static uint8_t img_cnt = 0;
    static uint16_t img_color;
    static void init(void *data) {
        img_cnt = 0;
    static void enter(void *data) {
        // insert code
        img_color = tmos_rand() >> 8;
        LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, img_shutter_96_bits, img_color, BLACK);
    static void loop(void *data) {
        KEY_TYPE key;
        key = HAL_KeyGet();
        switch (key) {
        case KEY1_SHORT:
            hidEmuSendConsumerReport(VOL_DOWN, 0x00);
            hidEmuSendConsumerReport(0, 0);
            img_cnt = 0;
            manager_startEventOnce(10);
            break;
        case KEY1_LONG:
            break;
        default:
            break;
    static void event(void *data) {
        if (img_cnt < IMG_NUM) {
            LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, &img_shutter_96_bits[1152 * img_cnt],
                    img_color, BLACK);
            manager_startEventOnce(30);
            img_cnt++;
    static void quit(void *data) {
        // insert code
  • Assemble the circuit
    MakerM0 • 01/28/2023 at 09:02 • 0 comments
    After a long time, finally there was time to continue the project, and I welded a complete set of boards.
    This is the schematic of CH582f board.
    Power on, firmware can be downloaded normally.
  • Test the 0.85 Inch Display
    MakerM0 • 12/05/2022 at 08:19 • 0 comments
    I have a 0.85-inch IPS display, GC9107, its resolution is 128X128, support SPI interface, for this I drew a PCB.
    After a period of waiting and debugging, I successfully used CH582M to light up the 0.85-inch display, and ported the µGUI.
    • MOSI------------PA14
    • SCLK------------PA13
    • CS---------------PA15
    • DC---------------PB4
    • BL----------------PB7
    • RST--------------PB15
    The project source : CH582M_spi.zip
