Assemble the shell
02/17/2023 at 07:23 • 0 commentsI took the time to print the shell using a 3D printer, then sanded and painted it.
It looks pretty good.
If you use CNC, the effect will be better
add stopwatch function
02/09/2023 at 08:39 • 0 comments![]()
The display of the stopwatch is controlled according to different keys;
event is responsible for the display content;
loop is responsible for controlling the operation according to the condition of keys.
#include "stopwatch.h" static uint32_t record[8]; static uint8_t id; static bool flag_start; static bool flag_pause; static bool flag_reset; static bool flag_update; static bool flag_record; static uint32_t time_pause; static uint32_t time_pause_sum; static uint32_t time_start; static uint32_t time_stop; static void init(void *data) { tmos_memset(record, 0, 8 * 4); flag_start = false; flag_update = false; flag_record = false; flag_reset = false; flag_pause = false; time_pause_sum = 0; time_pause = 0; id = 0; } static void dispMs(uint32_t ms) { char buffer[15]; uint16_t x, y; // UG_FillFrame(0, 0, 128, 25, C_BLACK); UG_FontSelect(FONT_12X20); UG_SetBackcolor(C_BLACK); UG_SetForecolor(C_SNOW); snprintf(buffer, 15, "%02d:%02d:%03d", ms / 1000 / 60, ms / 1000 % 60, ms % 1000); uint16_t title_width = UG_GetStringWidth(buffer); UG_PutString((LCD_W - title_width) / 2, 1, buffer); } static void dispRecord(uint8_t index) { char buffer[15]; UG_FontSelect(FONT_8X12); UG_SetBackcolor(C_BLACK); UG_SetForecolor(C_DARK_GREEN); snprintf(buffer, 15, "%02d:%02d:%03d", record[index] / 1000 / 60, record[index] / 1000 % 60, record[index] % 1000); UG_PutString(45, 28 + index * 12, buffer); } static void enter(void *data) { // insert code UG_FillScreen(C_BLACK); UG_SetBackcolor(C_BLACK); UG_SetForecolor(C_SNOW); dispMs(0); UG_DrawLine(0, 25, 128, 25, C_GREEN); UG_FontSelect(FONT_8X12); UG_SetForecolor(C_DARK_GREEN); for (uint8_t i = 0; i < 8; i++) { UG_PutChar(i + '1', 10, 28 + i * 12, C_DARK_GREEN, C_BLACK); UG_PutString(45, 28 + i * 12, "__:__:___"); } manager_startEvent(222); // manager_setBusy(false); } static void event(void *data) { if (flag_update == true) { // 开始刷屏 uint32_t time_consume; time_consume = millis() - time_start - time_pause_sum; dispMs(time_consume); } if (flag_record == true) { flag_record = false; record[id] = time_stop - time_start; dispRecord(id); id++; if (id >= 8) { id = 0; } } if (flag_reset) { flag_reset = false; flag_start = false; flag_update = false; flag_record = false; flag_pause = false; time_pause_sum = 0; time_pause = 0; id = 0; dispMs(0); UG_FontSelect(FONT_8X12); UG_SetForecolor(C_DARK_GREEN); for (uint8_t i = 0; i < 8; i++) { UG_PutChar(i + '1', 10, 28 + i * 12, C_DARK_GREEN, C_BLACK); UG_PutString(45, 28 + i * 12, "__:__:___"); } } } static void loop(void *data) { KEY_TYPE key; key = HAL_KeyGet(); switch (key) { case KEY1_LONG: manager_switchToParent(); break; case KEY1_DOWN: if (flag_start == false) { //first time_start = millis(); flag_start = true; flag_update = true; flag_record = false; } else { if (flag_pause == false) { flag_record = true; time_stop = millis() - time_pause_sum; } else { time_pause_sum = millis() - time_pause + time_pause_sum; flag_pause = false; flag_update = true; } } break; //pause case KEY2_DOWN: flag_update = false; flag_pause = true; time_pause = millis(); break; //reset case KEY3_DOWN: flag_reset = true; break; default: break; } } static void quit(void *data) { // insert code manager_stopEvent(); manager_setBusy(true); } -
Add shutter function
02/09/2023 at 06:43 • 0 comments![]()
Split GIF image in frames (ezgif.com)
I use this website to convert gif files to multiple jpg files and then to .c files, use TMOS to update a picture every 100ms, and perform animations when the keys are pressed.
#include "shutter.h" #include "img_shutter.h" #include "img_shutter_96.h" #include "hidconsumer.h" #define IMG_NUM (img_shutter_96_height/img_shutter_96_width) static uint8_t img_cnt = 0; static uint16_t img_color; static void init(void *data) { img_cnt = 0; } static void enter(void *data) { // insert code UG_FillScreen(C_BLACK); img_color = tmos_rand() >> 8; LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, img_shutter_96_bits, img_color, BLACK); // manager_setBusy(false); } static void loop(void *data) { KEY_TYPE key; key = HAL_KeyGet(); switch (key) { case KEY1_SHORT: hidEmuSendConsumerReport(VOL_DOWN, 0x00); hidEmuSendConsumerReport(0, 0); img_cnt = 0; img_color = tmos_rand() >> 8; manager_startEventOnce(10); break; case KEY1_LONG: manager_switchToParent(); break; default: break; } } static void event(void *data) { if (img_cnt < IMG_NUM) { LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, &img_shutter_96_bits[1152 * img_cnt], img_color, BLACK); manager_startEventOnce(30); img_cnt++; } } static void quit(void *data) { // insert code manager_stopEvent(); // manager_setBusy(true); } -
Assemble the circuit
01/28/2023 at 09:02 • 0 commentsAfter a long time, finally there was time to continue the project, and I welded a complete set of boards.
This is the schematic of CH582f board.
Power on, firmware can be downloaded normally.
Test the 0.85 Inch Display
12/05/2022 at 08:19 • 0 commentsI have a 0.85-inch IPS display, GC9107, its resolution is 128X128, support SPI interface, for this I drew a PCB.
After a period of waiting and debugging, I successfully used CH582M to light up the 0.85-inch display, and ported the µGUI.
- MOSI------------PA14
- SCLK------------PA13
- CS---------------PA15
- DC---------------PB4
- BL----------------PB7
- RST--------------PB15
The project source : CH582M_spi.zip
MakerM0
