Split GIF image in frames (ezgif.com)
I use this website to convert gif files to multiple jpg files and then to .c files, use TMOS to update a picture every 100ms, and perform animations when the keys are pressed.
#include "shutter.h"
#include "img_shutter.h"
#include "img_shutter_96.h"
#include "hidconsumer.h"
#define IMG_NUM (img_shutter_96_height/img_shutter_96_width)
static uint8_t img_cnt = 0;
static uint16_t img_color;
static void init(void *data) {
img_cnt = 0;
static void enter(void *data) {
// insert code
UG_FillScreen(C_BLACK);
img_color = tmos_rand() >> 8;
LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, img_shutter_96_bits, img_color, BLACK);
manager_setBusy(false);
static void loop(void *data) {
KEY_TYPE key;
key = HAL_KeyGet();
switch (key) {
case KEY1_SHORT:
hidEmuSendConsumerReport(VOL_DOWN, 0x00);
hidEmuSendConsumerReport(0, 0);
img_cnt = 0;
manager_startEventOnce(10);
break;
case KEY1_LONG:
manager_switchToParent();
break;
default:
break;
static void event(void *data) {
if (img_cnt < IMG_NUM) {
LCD_DrawMonoXBMFast(16, 16, img_shutter_96_width, img_shutter_96_width, &img_shutter_96_bits[1152 * img_cnt],
img_color, BLACK);
manager_startEventOnce(30);
img_cnt++;
static void quit(void *data) {
// insert code
manager_stopEvent();
manager_setBusy(true);
