Hello Air Cruiser, I'm designing a carbon frame for the DJI FPV and would like to use common 6S batteries to get more power from the drone. I found your project, and I would like to know more about how you solved this issue. I appreciate it if you can provide me with more information. Greetings from Colombia.
Great Aircruiser!! Are you still working on this project?
Thank you :)
