Here I would like to present some ideas and solutions for self-made battery packs.
BatteryCase_18650_Cover (New).stlCover for the 18650 Battery CaseStandard Tesselated Geometry - 24.50 kB - 02/28/2023 at 21:47 |
Landing_Gear.stlThe "shoes" of the battery cases. Highly recommended to be printed with TPU (or other soft filaments).Standard Tesselated Geometry - 11.02 kB - 01/05/2023 at 22:41 |
BatteryCase_18650.stlCase for 18650 LiIon cellsStandard Tesselated Geometry - 480.36 kB - 01/05/2023 at 22:41 |
BatteryCase_DJI.stlCase for original DJI LiPo cellsStandard Tesselated Geometry - 369.81 kB - 01/05/2023 at 22:41 |
BatteryCase_21700_Bottom.stlBottom cover for the 21700 LiIon casesStandard Tesselated Geometry - 88.95 kB - 01/05/2023 at 22:40 |
How did you manage not to lock the BMS during your modifications?
Did you always provide enough voltage for the BMS to think the battery is not deep discharged?
How do you charge the batteries?
Is a locked BMS still useable for you mod?
I have an original FPV battery thats locked and can't charge the normal way. Maybe I can use them as a replacement if the cells in the other batteries start to fail. But I don't know how to swap them without triggering the BMS lock.
Did you try to hack the drone's firmware?
https://i.imgur.com/mQOWKIv.png
I also need to know how to do that without looking the BMS
