New video
01/01/2017 at 14:21 • 0 commentsNow added a video with the first five light effects based on the FastLED lib.
Top of the tree
12/13/2016 at 20:19 • 0 commentsNow I have added the 193th LED at the top of the tree. A WS2812 8mm LED from Adafruit, which I have ordered a long time ago for testing purpose. After some try and error I figured out, that this LED needs RGB byte order instead of GRB like the WS2812 at the LED rings. So I decided to use a different GPIO pin of the Teensy to drive this single LED.
Assembly
12/07/2016 at 05:19 • 0 commentsI have just assembled the acrylic tree with the 7 LED rings. I am also planning to add one special LED at the top of the tree. Using a Teensy 3.5 board and a 74HCT745 level shifter, next step will be the programming of different lightning effects. Should be finished before Christmas...
makeTVee
