Improving the steering mechanism
A project log for Autonomous RC car
My attempt at robot Folkrace
martin-plssonMartin Pålsson 07/22/2017 at 08:311 Comment
The original steering servo broke down early in the development. I found that a SG90 fits into the mounting bracket easily, just a little filing was necessary. Though it is mounted the other way. I have used a cheap TowerPro SG90 but there are many high end servos that might fit out there.
The A242 is well known for having a large turn radius. By filing out some plastic in the steering column the steering radius was greatly reduced. See the pictures:
Results:
marc wrote 03/14/2018 at 22:30 point
Hi, Can you explaind me how you did that mod? thanks
