I could not resist the temptation to add a logo to the case. Also made the case a bit taller to remove the humps for the GPS antenna and temperature sensor.
![](https://cdn.hackaday.io/images/3917881670220871776.png)
![](https://cdn.hackaday.io/images/5699951670220993430.jpg)
A project log for Squeak: GPS pet tracker
Squeak is a LoRaWAN GPS pet tracker with a very long battery life. It allows you to ask your pets to share their location
