So sew files only give deltas of movements, not absolute values so if my starting point or one byte is off, it messes up the whole image. With this, I decided to just plot the deltas, expecting on my card there to be a lot of back-and-forth movements.
First I tested on the known good file (downloaded from the internet):
And my readout:
"832 DATA EXP L V" which looks like it could be a header. Then a little further along, there's this in a sea of non-ascii characters:
After some trial and error, I stopped using the A-1 address pin (which is suppose to be the LSB) and got this
