This one has the provision for stowing, the mounting points, the switch.
Despite the clean renders in Blender, it was still a hot glue mess. There has to be a lot of extra wire in order to disassemble it.
The mane concern is how stiff the steering is. There's a lot of friction in those PLA bushings. It may end up requiring ball bearings with hall effect sensor. The string slit could be moved farther out.
