The IP2312 is a synchronous switch step-down battery charging IC. It features:
- Synchronous switch step-down charging
- Charging efficiency 94% (3.7V/2A)
- Maximum charge current 3A
- Charging current external resistance can be adjusted
- Automatically adjust the input current, compatible with small current adapters
- Support 4.20V/4.30V/4.35V/4.4V battery
- Support charging NTC temperature protection
- Support LED charging status indication
- Built-in power MOS
- 750KHz switching frequency, can support 1uH inductor
- Input overvoltage and undervoltage protection
- IC over temperature protection
- Charging overtime protection
The maximum charging current can be set by resistor R4 (ISET): ISET = R4 = 135kV / I_CHARGE
| Max Charging Current | R4 (ISET) |
| 1A | 135k |
| 1.5A | 91k |
| 2.1A | n.c. |
| 3A | 45k |
The maximum charging voltage can be set by resistor R6 (VSET):
| Max Charging Voltage | R6 (VSET) |
| 4.2V | n.c. |
| 4.3V | 43k |
| 4.35V | 75k |
| 4.4V | 100k |
Stefan Wagner
Sagar 001
Walid Issa
Lithium ION
