1Setup Cellular Connectivity for AccessHAT
This set up was done using the Raspberry Pi 4B + AccessHAT + CellCM.
- Download the Raspberry Pi 32-bit OS from https://www.raspberrypi.com/software/ on an SD card and load it to your Raspberry Pi. Be sure to also download the AccessHAT drivers from https://github.com/makersolutions-io/accesshat_drivers
- Insert the SIM card into the CellCM, ensuring the orientation is correct. Refer to the image below. *Please note that you will need to contact your service provider for an APN.
- Connect the CellCM to the AccessHAT.
- Connect the antennas to the CellCM at Main and Div.
- Connect the AccessHAT to the Raspberry Pi.
- Connect a USB cable (A-male to mini B-male) from the Raspberry Pi to the AccessHAT.
- Power up the system by connecting the power supply to the barrel jack in the AccessHAT.
Commands to Establish the Cellular Interface
- Enable cellular module and wait about 30 seconds for the Raspberry Pi to recognize the modem.
gcc enable_cellcm.c -laccesshat -lwiringPi
sudo ./a.out
- Check that ModemManager finds the modem.
mmcli -L
Should see something like this:
/org/freedesktop/ModemManager1/Modem/0 [Telit] LE910-NA1
- Enable modem and check primary port. This command shows the interface name (primary port) under System | primary port.
mmcli -m 0 --enable
mmcli -m 0
If ModemManager shows /Modem/1, change the commands to mmcli -m 1.
- Add cellular connection through NetworkManager.
nmcli c add type gsm ifname <primary port> con-name <name> apn <operator_apn> username <user> password <password> pin <PIN>
Example:
nmcli c add type gsm ifname ttyACM0 con-name cell apn myapn.com
For a detailed explanation and other configuration options, read:
https://ubuntu.com/core/docs/networkmanager/configure-cellular-connections
