This is a raspberry pi powered tablet, which uses android OS which makes it look like a google phone. You can make this a phone or a tablet.
7inTouchCase.stlAdafruit's tablet case.Standard Tesselated Geometry - 124.40 kB - 12/03/2022 at 14:42 |
Attach the ribbon cable from the raspberry pi to the screen and put the two wires in connecting the power. Screw the raspberry pi into place.
Go to Emteria.com and download the installer. Once that is done, open the installer and follow the steps to download the OS onto the SD card. Plug it into the raspberry pi and turn it on. Follow the setup instructions. If you tap a few times on the thing you are writing on a keyboard should come up.
Print the case and attach it.
