1Add Raspberry Pi
Attach the ribbon cable from the raspberry pi to the screen and put the two wires in connecting the power. Screw the raspberry pi into place.
2OS Download
Go to Emteria.com and download the installer. Once that is done, open the installer and follow the steps to download the OS onto the SD card. Plug it into the raspberry pi and turn it on. Follow the setup instructions. If you tap a few times on the thing you are writing on a keyboard should come up.
3Printing
Print the case and attach it.
4Try out the different apps
You can try out the different apps and you can plug in the microphone/speaker and you can call, text, play games, tell the time, tell battery life, and more.
