Microchip XC16 Arduino - PIC24F, dsPIC33
* Executing task in folder PK4: C:\Users\1124\.platformio\penv\Scripts\platformio.exe run --target upload --target monitor --environment WizIO-PIC24FJ256GB206
Processing WizIO-PIC24FJ256GB206 (platform: XC16; board: WizIO-PIC24FJ256GB206; framework: Arduino)---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
Verbose mode can be enabled via `-v, --verbose` optionCONFIGURATION: https://docs.platformio.org/page/boards/XC16/WizIO-PIC24FJ256GB206.htmlPLATFORM: PlatformIO - PIC24 (1.0.0+sha.66f4891) > WizIO-PIC24FJ256GB206HARDWARE: 24FJ256GB206 16MHz, 32KB RAM, 256KB FlashPACKAGES: - framework-XC16 @ 1.0.0+sha.ebc9b32 XC16 : 1.5 CORE : PIC24F CHIP : 24FJ256GB206LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldfLDF Modes: Finder ~ chain, Compatibility ~ softFound 2 compatible librariesScanning dependencies...No dependenciesBuilding in release modeCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\Print.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\Stream.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\WMath.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\WString.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\cbuf.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\dtostrf.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\new.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\wiring_pulse.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\wiring_shift.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\arduino.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\missing.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\wiring.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\wiring_digital.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\variant\board.oCompiling .pio\build\WizIO-PIC24FJ256GB206\arduino\variant\variant.oCompiling .pio\build\WizIO-PIC24FJ256GB206\src\fuses.oCompiling .pio\build\WizIO-PIC24FJ256GB206\src\main.oLinking .pio\build\WizIO-PIC24FJ256GB206\APPLICATION.elfCreating HEX .pio\build\WizIO-PIC24FJ256GB206\APPLICATION.hexConfiguring upload protocol...AVAILABLE: PK4CURRENT: upload_protocol = PK4Uploading... Device : PIC24FJ256GB206 Programer : PICKIT4 Driver : BUR181018704 Serial Number : BUR181018704 Voltages : (3172, 3115, 280, 2856, 0, 25000, 2, 0) ICSP Speed : 400 Device ID : 0x41040004Erasing Chip...Program Application...Program Configiguration bits... DONE===================================================================================================== [SUCCESS] Took 8.88 seconds
View project log
https://www.youtube.com/watch?v=PiL7RAr3POE
The interesting thing is that it works...
https://github.com/Wiz-IO/XC16
tamberg
Open Technology
Hari Wiguna
Ricardo Lima Caratti
Yes, delete it Cancel
You are about to report the project "Microchip XC16 Arduino", please tell us the reason.
