LOG from PlatformIO
12/23/2022 at 16:13 • 0 comments* Executing task in folder PK4: C:\Users\1124\.platformio\penv\Scripts\platformio.exe run --target upload --target monitor --environment WizIO-PIC24FJ256GB206
Processing WizIO-PIC24FJ256GB206 (platform: XC16; board: WizIO-PIC24FJ256GB206; framework: Arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/XC16/WizIO-PIC24FJ256GB206.html
PLATFORM: PlatformIO - PIC24 (1.0.0+sha.66f4891) > WizIO-PIC24FJ256GB206
HARDWARE: 24FJ256GB206 16MHz, 32KB RAM, 256KB Flash
PACKAGES:
- framework-XC16 @ 1.0.0+sha.ebc9b32
XC16 : 1.5
CORE : PIC24F
CHIP : 24FJ256GB206
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 2 compatible libraries
Scanning dependencies...
No dependencies
Building in release mode
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\Print.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\Stream.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\WMath.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\WString.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\cbuf.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\dtostrf.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\new.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\wiring_pulse.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\api\wiring_shift.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\arduino.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\missing.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\wiring.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\core\wiring_digital.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\variant\board.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\arduino\variant\variant.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\src\fuses.o
Compiling .pio\build\WizIO-PIC24FJ256GB206\src\main.o
Linking .pio\build\WizIO-PIC24FJ256GB206\APPLICATION.elf
Creating HEX .pio\build\WizIO-PIC24FJ256GB206\APPLICATION.hex
Configuring upload protocol...
AVAILABLE: PK4
CURRENT: upload_protocol = PK4
Uploading...
Device : PIC24FJ256GB206
Programer : PICKIT4
Driver : BUR181018704
Serial Number : BUR181018704
Voltages : (3172, 3115, 280, 2856, 0, 25000, 2, 0)
ICSP Speed : 400
Device ID : 0x41040004
Erasing Chip...
Program Application...
Program Configiguration bits...
DONE
===================================================================================================== [SUCCESS] Took 8.88 seconds
Georgi Angelov
