This recommendation had more information than any others, including a parts list.
https://www.amazon.com/dp/B07TLK4956
The teflon sliders are super expensive. Would try using teflon sheets & double sided tape.
https://www.amazon.com/KAILH-Official-Chocolate-Mechanical-Keyboard/dp/B0B3MLZJ8K
He had good results using mechanical keyboard keys for buttons but they're super expensive.
Just the teflon & the buttons would burn $30. The mane difficulty was the scroll wheel. The best he could do was put it on the side. He used a clickless encoder.
The problem is so hard, the lion kingdom started pondering trackballs again. The scroll wheel is really hard. It would ideally be a mechanical keyboard key with a wheel.
