This is my PoE module development process.
PoE development process for Wiznet Ethernet Chip.
There are all the data and experiments in the log. Look at the Log!
I'm a developer of Wiznet, and I am studying and experimenting with hardware a lot.
This project is for Wiznet Chip.
Materials related to Wiznet are available on the following site.
Alan
This switching hub supports only Mode B. And unfortunately, the maximum spec is 7W, so I tested up to 7W.
As a natural result, Mode B also has no problem.
The board on which the module is installed is the W5100S-Mining board mentioned in the previous Log. This board consumes a total of 3W.
I thought a lot of heat would occur, but it didn't occur at all.
Quinn
OzQube
You're very capable. Did you finish this high-quality circuit design and artwork by yourself?
It would be great if it could be a movement.I respect you
