1Unpack your Kit
The kit comes with:
- 1 - Krampus
- 2 - 3mm Red LEDs
- 1 - Battery Holder
- 1 - CR2032 Battery
- 1 - Length of chain
- 1 - Jump ring
2Place LEDs into holes
Be sure to place LEDs in same direction (if long leg is going through top hole for the first LED then the long leg needs to go through the top hole on the 2nd LED) Bend LED legs once going away from the center and one going towards the center (make sure to keep bending consistent on each LED (if you bend the negative leg away and the positive towards repeat for all LEDS
3Twist LED Legs together and add the resistor
Grab the two negative (short) LED legs and twist them together 3-4 times. Then grab the two positive (long) LED legs and twist them together 3-4 times. Grab your resistor and twist together with the positive legs. After the LED legs and resistor are twisted together, fold the legs in half.
4Attach the battery holder
Wrap the negative battery holder wire around the two negative LEDs legs. Then fold over. Wrap the positive battery holder wire around the resistor and then fold over. Optional step is to cut off extra resistor or battery holder wire.
5Attach the chain and jump ring
Take the jump ring and bend to make an opening. Put through the chain and then thread the chain through the loop on Krampus. Then put the other end of the chain on the jump ring and bend back to the ends are touching and the ring is closed.
6Place battery in battery holder and turn on!
The battery sits in the battery holder and is held in place once the battery holder is closed.
