Final fix
01/08/2017 at 02:51 • 0 commentsI corrected last line to compensate 3-cycle overhead for every frame and also fixed order of patterns at the bottom of the screen - perfect version to burn my 1st OTP MCU :)
Final version is 445 words long (87% of PIC12C508) and available on GitLab
Source code also has schematics in it as a comment:
; +5V ; .--* ; # | PIC12C508 ; 470* # | ---v--- ; # \--|1 8|- GND ; | NC -|2 7|--###-\ 1.5 kOhm ; SYNC *-----|3 6|--###--* 680 Ohm ; | IN -|4 5|--###-/| 330 Ohm ; | ------- | ; ----------------###--*---> VIDEO (8 gray levels) ; 1 kOhm
UPDATE: Another 2 TVs running by OTP PC12C508A, both SONY - big CRT one (4:3):
and big LCD one (16:9):
with video :)
As you can see last few shades (5,6,7) are too bright and looks all white (may be because of 1.5V max amplitude). Also there is a space for 48th column on the left side - I'll add it in the next version that will be re-written for heavy macros usage to represent repeating code for visibility purposes...
Fixed
01/06/2017 at 05:45 • 7 commentsIt's already a little bit too late, but this is a fix to make frame sync work :)
--- a/PIC12-T1.ASM +++ b/PIC12-T1.ASM @@ -23,7 +23,7 @@ Line_: movwf TempN ; 1/7 Line_loop: ; 15*3-1=44/51 decfsz TempN,f ; (1/1) - goto Line0loop ; (2/3) + goto Line_loop ; (2/3) nop ; 1/52 clrf GPIO ; 1/53 -> video 48
Now image is solid:Files in the project still have version without frame sync, but GitHub is fixed
P.S. Top of the image is a little off because of GOTO at the and and CLRF in the beginning of the program - 3 extra cycles per frame that should be eliminated in future version...
ANALYSIS: As you can see it's only 4 different brightness levels, not 8 - In this version of the program GP2 is not set as output because T0CS in OPTION register has to be cleared (it's 1 by default) if we need to use GP2 as output. Also you can see 47 columns, not 48 - I'll fix it in the next version...
FIX for OPTION:
--- a/PIC12-T1.ASM +++ b/PIC12-T1.ASM @@ -8,8 +8,8 @@ LineN EQU 0x08 ; line counter TempN EQU 0x09 ; temporary counter movwf OSCCAL ; store factory calibration value - movlw 7 - movwf Seven + movlw 0xC0 + option goto loop
New screenshot with 8 shades of gray:It's patterns 1,2,3,4,5,6,7,0 (incf) and 1,6,1,6,1,6,1,6 (comf)
Also I reduced pull-up resistor (from GP4 to +5V) - now it's 480 Ohm (too small?):
1st run
01/06/2017 at 04:36 • 0 commentsI connected 1.5 kOhm resistor to GP0, 680 Ohm to GP1, 330 Ohm to GP2 and 1K to GP4 (sync) - all of them connected together create analog VIDEO. Program for PIC12C508A is PIC12-T1.ASM (429 words or 643.5 bytes). Result:
Trying to see what is going on - probably just resistor values have to be corrected...UPDATE: After pulling-up GP4 with 2K resistor it's a little bit more stable:
Test setup:
Line of the Raster
01/05/2017 at 06:05 • 0 commentsSo we will have 64 uS line where:
- 4 is blank before sync
- 5 is a sync
- 7 is blank after sync
- 48 is visible screenPIC12C508/509 don't have interrupts, so we will simply call Line(s) subprogram(s) multiple times to generate proper raster:
; call ; 2/2 Line: nop ; 1/3 nop ; 1/4 ; video 48 instructions /52 ... clrf GPIO ; 1/53 -> video 48 nop ; 1/54 nop ; 1/55 movlw 0x08 ; 1/56 tris GPIO ; 1/57 incf LineN,f ; 1/58 -> sync nop ; 1/59 -> sync nop ; 1/60 -> sync movlw 0x18 ; 1/61 -> sync tris GPIO ; 1/62 -> sync retlw 1 ; 2/64
For frame sync it will be special Line subprogram...
