@otcpp in python to c lib for python
05/04/2023 at 02:32 • 0 commentsBy using `@otcpp` as decorator python It's making a c libary importable / from global variable. Build real .c file gcc it. definition of function / method / is yyy funny but :P
as a draft
Some time now : moving to repository
04/10/2023 at 13:04 • 0 commentsYes it was some time since I post some updates about OiyshTerminal on hackaday. I was focus on writing / conceptualizing. I decided I will not fragment more my time.
It's nothing else as duplicating same information showing up on github so
If you are interested in project / want to engage / contribute
stare / fallow repository on github and source updates / issues from there
ot-plc-phantom-to-battery-node
03/20/2023 at 15:03 • 0 commentsThis is a experiment as a result of previews log entry. I think opening open doors is yyy for the sake of it ok. But it's open.
Node-RED is not 100% fit to the job but 99.9% there. So idea is to move this logic arranged with some help of custom nodes to Flows. Connecting outputs with inputs. Is what all can do. For now is at 0.0.5 version it it I have nodes in early stages of phantom-to-battery
This tiny thing is Wow.
Read more in depth description what is going on whit it. link... to working example
Or Teaser
are we there yet ?
03/19/2023 at 12:11 • 0 commentsCouple of days a go I decided that I will try to implement a yss site with specks / usability of someone else then me. I don't know if you know https://openmuscle.org/ it's a interesting project. It can change a lot it how we see HMI to give people new fingers, arms, wrist, ......
Task was to make a visualization of upcoming data samples from hardware. They used UDP protocal and device is sending json'ish lines of adc channels. Have a place to trouble shoot sensors reading / over all diagnostic. Make a place to start section with ML. oiyshTerminal can help!
With yss it's easy. I made a flow to listen to packages in udp then istore it in influxDB to have nice resolution in ms or more Then it was a meter of making .svg with two versions 4ch and 12ch. Top-ing on the cake is grafana and plots abilities. All that in less then 30 min with finally .deb made with packitso ....
More about otdmp-open-muscle-src: link ...
Nice screen of it working on provided data from stored stream from file rebroadcast recapture and displayed.
On left two devices with some fast view for data coming now from device. On right grafana with some basic plot set up to check if data in coming to this point.
All this as a target will be access able by
apt install otdm-yss otdmp-open-muscle-src
If all is good.
KNOWN BUGS ON CURRENT VERSION
For sure the grafana dashboard will not install it self correctly (can make manually and package is comming)
There is no grafana installer in otdm (can make manually and package is comming)
Let me know what you think about this fast telemetry method. And if you have a project where you want to see telemetry / interaction with device / system you have let me know I'm happy / interested to check if I / oiyshTerminal can help!
plc in growing in my head
03/16/2023 at 16:52 • 0 commentsSo started from some simple api to get only topics list in system now is slowly starting to be a plc in / out manager layer.
Image it! - drawing is helping me with finding what is where This is a big decision to make. Possibilities main blowing. One instrument set by default is working in telemetry mode. As mqtt telemetry can be. With idea of `Bundles` this is object orientated.
No difference if you check battery at your car in garage, rc model charger, battery in green house, .... it's a `Bundle` battery.
If sensors channels / topics by plc api will get name, bundle, type of value, unit, post process for data if needed. Then any multimeter site in yss can do all them not knowing from where is it's sourced. Bum Nice!
You want to get all possible alarms emitters in your system. One query to api.
IoT automatized
If plc api will collect new traffic it will be a nice source of new sensor in your system to set in up as bundle or define nicer name set units.
Check drawing and let me know what scenario can't be managed with this...
More on wiki link ...
packitso spit out p- ..... .deb
03/15/2023 at 17:42 • 0 commentsCircle of this route with this one what I made is funny for me. As OT is i have mainly guts filing how what should go and fact that it's my 5'th or so attempt to normalize and fragmentation it to the POWER! with power full dependency solver in my sleeve. THX dpkg ! bash and all other perfection things !
but circle.
Started from camera that there was a plan to make images from time to time to have something to process. Read number from image. Things for today standard normal. This is OT and it's for off-line mainly. So. First of all https ....
S or not to s. If https all sensors: mic, camera, gps, .... from phone I can harvest them as sensors. Imagine no installation nothing. First phone with wifi and web browser. Entering yss page then selecting that you are a source of data on this device and bum.
new Input of .....
this is grate but https -> to http not so good I went to point where my custom https server handler of post'ing data was rerouting from https to http to be able to communicate new data from sensor. YYY a lot of windnes.
No https
you with your device on your server http with your page on it no. untrusdet and u2327404$@#$@%!
this lead to many incoming new data from many devices audio, images, gyro, gps, lumens,....
otdmp-nrf-http-api-plc in coming for the rescue!
More about it link ...
yss-remote-camera
03/12/2023 at 18:49 • 0 commentsOk nothing new. But :P
This time you can turn any device with web browser and camera to your input data of images to do yyyyy what ever... we are at hackaday.io ?
For me is a remote camera to put it in dark corner or do timelaps...
One of many to come devices sensors data harvesting project ....
More about project: https://github.com/yOyOeK1/oiyshTerminal/wiki/otdm-yss-remote-camera
otdm-grafana-btzoom : as some new .js in the house !
03/10/2023 at 17:35 • 0 commentsGrafana is really nice app. If you want to make some fast data visualization / plots / tables Grafana is your choice! But but but :P in my opinion ratio of represented data to candy eye element is not so good. In this moment otdm-grafana-btzoom is coming to the help !
Second image is after adding new future url argument &otgOnly=2 to maximize second element on this dashboard!
Bum how to install link ...
pushing yss-project-manager baobab way
03/06/2023 at 19:00 • 0 commentsThis one is coming as all rest with twist :P presenting your tasks as ready bannanas in baobab view style :)
No pressure
Read more about it: link...
otdm-yss-packitso update ...
03/03/2023 at 23:01 • 0 commentsOk It can some thing now.
Node-RED flow to .deb - no problem !
Grafana data source to .deb - no problem !
All updates on status of coding now updated at: https://github.com/yOyOeK1/oiyshTerminal/wiki/otdm-yss-packitso#otdm-yss-packitso
