3D Printed Repeating Crossbow/Sling Shot Pistol
This is my attempt at a narrow crossbow/sling shot pistol that is mostly 3D printed.
I've always wanted to have a crossbow pistol for myself, but I never liked the width the bow required. The Fox-III is my attempt at creating such a narrow crossbow/sling shot pistol. It has been inspired by the 3D printed Adderini pistol (https://cults3d.com/en/3d-model/various/adderini-3d-printed-repeating-slingbow-pistol) and the wooden versions created by JoergSprave on the Sling Shot Youtube channel.
My "improvements" are:
** The use of standard surgical tubing looped back on its self to allow for a longer draw without excessive width.
** Different surgical tubing selections allows for a wide range of draw weights.
** A rolling block style string catch to significantly increase the strength of the catch.
** A trigger mechanism that allows the slide to move independently from the actual trigger.
** Using a series of bearings on the high load joints to allow longer service at higher loads.
** A safety switch to help prevent accidental discharges.
All the STL, STEP, and FreeCAD files can be found on GrabCAD.
The rolling block trigger is one of the key features of this design.
The size of the rolling block makes for a very strong string catch, while the trigger design allows for the easy inclusion of a safety switch as well as allowing the slide to move independently from the trigger. The various bearings should allow for smooth operation even with high loads.
I designed two versions of the cocking arm, one that latches and one that does not. The non latching version is held in the cocked position by maintaining a grip on the handle of the pistol. The non-latching version provides an additional safety feature so that it can not be left unattended in the cocked position.
Delrin double v-groove wheels are used for the bow string pulleys as they provide a low cost readily available low friction solution to handling the bow string. The surgical tubing wraps around a custom pulley to double back on itself. This allows the tubing to be longer for the same draw length.Various tubing is available to allow for different draw weights from very light to very heavy.
The files were designed to be printed on a 300x300mm 3D printer, but I also created a split version that can be printed on smaller printers.
When the pistol is not cocked it should be easy to pop the tubing off the front pulleys so that the tubing is not left under tension when not required.
STLs.zip
All the STL files
x-zip-compressed - 14.44 MB - 11/11/2023 at 21:39
Download
Steps.zip
All the STEP files
x-zip-compressed - 42.37 MB - 11/11/2023 at 21:41
Download
FreeCAD Files.zip.001
Part 1 of 5 of the FreeCAD files ZIPed with 7zip.
001 - 35.00 MB - 11/11/2023 at 21:41
Download
FreeCAD Files.zip.002
Part 2 of 5 of the FreeCAD files ZIPed with 7zip.
002 - 35.00 MB - 11/11/2023 at 21:41
Download
FreeCAD Files.zip.003
Part 3 of 5 of the FreeCAD files ZIPed with 7zip.
003 - 35.00 MB - 11/11/2023 at 21:41
Download
View all 7 files
  • 4 × Double V Groove Wheel
  • 4 × 625-2RS Bearing (5x16x5mm)
  • 8 × MR85-2RS Bearing (5x8x2.5mm)
  • 31 × M3 Hex Nut
  • 6 × M3 x 10 Hex Socket Button Head Screw
View all 35 components
View project log
Kaan BEKAROGLU wrote 03/11/2023 at 14:54 point
When will it be available? I would love to print it!!!!
278654727 wrote 02/12/2023 at 15:37 point
How can I download this crossbow? Can you design a crossbow that fires 8mm?
278654727@qq.com
fluxslinger88 wrote 02/10/2023 at 18:43 point
Amazing. The trigger assembly is very nice.
