1Step 1
Firstly, solder the FT2232D chip as it is the hardest to assembly. Its pitch is very dense and if the board you are using has been made using HAL there might be to much solder on the pads. You might want to take it off.
2Step 2
After that the passive components first, that is (mostly 0603) resistors and capacitors.
3Step 3
Solder MAX232, Oscillator and connectors.
Łukasz Przeniosło
