Using FPV technology to see what a competitive pistol shooter sees
I wanted to get this posted before the end of the FPV contest, but I missed the 9AM deadline. Oh well..
I got to the range yesterday and recorded some video. Unfortunately the video out from the headset was not working so I mounted the headset on a stand, set the mobile phone camera pointing at one eye display and looked at the other eye display.
I started with this 25mm M12 lens. Either the lens barrel or the camera female threads are not long enough to focus correctly. The focus at 50 ft was ok, but anything closer than that was significantly blurry. I don't know if they make M12 lens extensions or if I just got a dud lens.
Here is a 50 foot 5 shot string with a Feinwerbau 22 pistol and Aimpoint Micro red dot scope.
Here is a 50 foot 5 shot string with a RRA 1911 45 pistol and Aimpoint Micro red-dot scope, including an oopsy shot.
And for those of you open sight shooters, I tried 2 lenses. First the 25mm lens, which needs to be focused closer than the threaded barrel will allow. This is really quite useless.
I then tried a lens marked '45°' which I think is about 8mm focal length. The resolution of the target and sights just isn't good enough to shoot accurately.
Version 1 is a quick prototype using a bunch of old parts.
My camera is an older version of the Phoenix. It is a 1/2" sensor and has an M12 lens mount. This is important since we need much higher power, and smaller field of view to work in this application. The primary area of interest, the sights and target, are less than 1 degree wide. The strongest lens I have is labeled 45 degrees. I am waiting for a couple of stronger lenses to see what works best.
The smallest and cheapest cameras have M8 lenses which have a lot fewer lens options.
The camera and transmitter are mounted to a small piece of plastic. The plastic carrier is Velcroed to the front of the headset so it can be moved around and positioned right in front of the eye.
Fat Shark Transformer Binocular FPV Headset
Unfortunately the Transformer has been discontinued. I like it because it has a nice flat front face that makes it easy to mount the camera and it can be detached and used as a monitor to replay the recorded video. BangGoods claims to have it available (as of Dec 30, 2022) but I am a bit suspicious. Let me know if you buy one.
A transmitter isn't necessary, and probably not desired. I used it in the first prototype because I new it would work right out of the box and it does. I am going to wire the video signal directly into the display and will re-purpose the transmitter to make a target view camera feed that can be saved separately or inset in the recorded video feed.
Batteries and wires
The headset display operates from 7-13V so a 2S li-po is a good choice. I got a Fat Shark 2S battery holder with the headset. The camera and transmitter operate over 20V so my first pass uses a 4S li-po I had laying around.
Next Steps
It works as it is now, but the lens is too weak resulting in low resolution of the bullseye that doesn't allow accurate aiming at the target. As soon as I receive a stronger lens I am going to the range to try it out.
The wiring needs to be cleaned up. It is pretty much just a hodge-podge to get something working. I want to wire the Video Out from the camera to the headset display and power both the camera and the display from the same battery.
This video was made 20 or more years ago. This is what I hope to be able to do on a fraction of the budget and with better quality. I was told the AMU (Army Marksmanship Unit) used a beam splitter and old camcorder parts to record this.
What a cool idea! I used to teach rifle marksmanship, and I found it difficult to explain visual concepts like sight alignment and sight picture to students in a safe and sensible way. Being able to pull up a video of someone doing it right wold have been really valuable. I also like the way this captures the whole process of taking a shot, including follow through and calling the shot. Nice work!
Thanks guys.
I'll have some pictures and hopefully a video up soon.
@mihai.cuciuc I just looked at your #Precision shooting training gun. That is awesome work, I've wanted a "poor man's SCATT" for years and tried several years ago with a laser pointer, digital camcorder and some primitive post-processing. It worked, but required a lot of time to get a good result. There are so many better graphics processing tools these days I suspect it would be a lot better and easier, but your solution is less complicated (at least in HW)
You are probably right that the best way will be with a beam splitter. My display is 720P, the camera is a little better (1/2" sensor, 1000TVL). I've used up to a 25mm lens and can still see some pixilation of the bullseye. I have a few other lenses coming later this week.
Awesome idea! Do you have any demo pictures with your results so far?
I don't think you need super strong lens though, but that does depend on the camera you're using. For my #Precision shooting training gun I tried using lens up to f=100mm but in the end I didn't need to. Just used the f=6mm wide lens and it was good enough for what I was trying to do.
However I do think for best results you'll also need to use a beam splitter as you'll want the target, sights, eye and camera on the same optical axis.
Love the concept! There's a lot of potential with drone FPV components that shooting sports can take advantage of. We've actually used FPV cameras as long-range target cameras for precision shooting, not really an original idea, but a see-through competitive pistol shotting viewer is a really cool concept! Never seen this implementation before!
Thanks Dan. I've seen several relatively inexpensive rifle scopes with built in cameras, but they won't work for my application due to the magnification and eye relief. They also require replacing the scope on the rifle.
