I needed a new Raspberry pi Zero, and found a great seller in Australia that does a whole heap of raspberry pi related products: search for seller porpy1.
This time i decided that instead of soldering the pins directly to the pads I would run short wires off them to relieve the mechanical stress. After that I hot glued the whole lot to keep it protected.
