A relatively simple mod, given the placement of the cuts to be made. Angle grinder with metal blades cut two straight lines. Table was snapped off with pliers, then sanded. Once again, the slot is slightly over sized. Cut on the inside of the lines peeps. Excess can always be filed away later... Light filing to clean-up.
tinkerzone
