USB to LoRa interface
Mounts like an USB stick in order to send and receive radio messages over long distances using only your browser as an inteface
Circuitpython based LoRa USB stick, which allows browser based (GUI) serial communication via WebUSB to LoRa and back
Communication adapter to any remote LoRa satellite device, e.g. remote sensing over distances of several kilometers. The device can be used for collecting sensor data from widely distributed devices with a time resolution of seconds.
Usage
>   Plug device in, opens up as USB stick (circuitpython)
>   Open .html file in Web Serial API compatible browser (Chrome, Edge, Opera; see https://developer.mozilla.org/en-US/docs/Web/API/Serial)
>   Use browser as GUI, connect to device and send/receive commands to/from device via serial interface
>   Commands will be forwarded via LoRa RFM98W radio chip to remote device
The intention was single command communication, not LoRaWAN or mesh networking.
USB_LoRa_220917.stl
3d printer file
sla - 19.22 kB - 02/01/2023 at 23:11
Download
circuitpython8.uf2
uf2 - 902.00 kB - 02/01/2023 at 22:43
Download
bootloader-usb_lora-v3.13.0.bin
octet-stream - 16.00 kB - 02/01/2023 at 22:42
Download
index.html.txt
plain - 4.99 kB - 01/08/2023 at 00:48
Download
usbLoRa.sch
eagle CAD schematic
x-kicad-schematic - 241.13 kB - 01/08/2023 at 00:45
Download
View all 7 files
  • 1 × microcontroller ATSAMD51G19A-MU (TQFN48)
  • 1 × RGB LED APA102_2020 (optional)
  • 1 × 3.3V regulator AP2112K-3.3TRG1
  • 1 × 16MBit Flash memory GD25Q16CEIGR
  • 1 × USB C plug connector, optional (https://www.adafruit.com/product/4932)
View all 15 components
  • 1
    ​Make PCB, solder components
    PCB services: Aisler.net (https://aisler.net/p/LIMNJTWW), PCBway, etc.
  • 2
    flash bootloader
    flash bootloader using .bin file, e.g. via JLink, see https://learn.adafruit.com/how-to-program-samd-bootloaders
    Command line instructions: -> JLinkExe -> connect -> ATSAMD51G19A -> SWD -> default -> loadbin bootloader...bin,0 -> r
  • 3
    Add Circuitpython
    mount device via usb, put into bootloader mode, upload circuitpython .uf2 file, upload circuitpython library bundle
View all 6 instructions
