1Make PCB, solder components
PCB services: Aisler.net (https://aisler.net/p/LIMNJTWW), PCBway, etc.
2flash bootloader
flash bootloader using .bin file, e.g. via JLink, see https://learn.adafruit.com/how-to-program-samd-bootloaders
Command line instructions: -> JLinkExe -> connect -> ATSAMD51G19A -> SWD -> default -> loadbin bootloader...bin,0 -> r
3Add Circuitpython
mount device via usb, put into bootloader mode, upload circuitpython .uf2 file, upload circuitpython library bundle
4Add GUI
upload .html file to device, adjust accordingly
5Put into case
3d printed case: https://www.tinkercad.com/things/gIFCSjOI2CM
6enjoy!
gruenst
