So I was working on the #aStrA : Aligned Strings format with attributesand the principles have resurfaced.
I also write an article on the subject, the current dev snapshot is at AS20241228.tgz.
It's still a dumb mark-new-release allocator but it is multithread-compatible, you can locate the buffer anywhere you like in data memory.
Yann Guidon / YGDES
