So with that I built a ROM image for a simple inversion. D0 would be the opposite of A0. I wrote a 2816 (16k eeprom) to do the test.
I tend to assemble circuits with the power on. To my surprise, this started oscillating before I was even finish building it!
![](https://cdn.hackaday.io/images/3294451674263589735.jpg)
![](https://cdn.hackaday.io/images/6666411674263631281.png)
What is not wired yet is all the extra address lines, which should not be critical, but I would expect to cause intermittent operation.
ok! that worked!
