Just because something works, doesn't mean it works well. It can be important to play with it and understand the limits to operation...
I grounded the remaining address lines, and started playing with values. After trying a variety of inductors and capacitors that all worked great and produced different operating frequencies I realized that an RC delay might also work just fine...
![](https://cdn.hackaday.io/images/1525771674264103155.jpg)
![](https://cdn.hackaday.io/images/4377761674264118633.png)
An RC delay actually worked with cleaner operation than the LC!
I was able to hit about 3MHz with a small cap and low resistor value. So the range of operation is great!
Next test is to apply it to something...
