Instructions for all 5 Circuit Candy Hearts & Black Circuit Candy Hearts
Unpack your kit:
1 - Battery Holder
1 - CR2032 Battery
1 - Flat-Top 5mm RGB LED
1 - Binder Ring
1 - Heart
Place the LED through the top of the board. Align the flat side of the LED with the flat side of the hole. Once the LED is all the way through bend the legs.
Wrap the red wire around the long leg of the LED. Then bend the LED leg back over capturing the battery wire. Repeat those steps with the black wire on the short leg. (Optional step is to cut off excess wire with wire cutters)
